Axcaliber Kitchen Worktop Cutter (Long Shank)
- Long Shank Worktop Cutter 1/2" Shank
- Bottom cut insert for efficient plunge cuts
- High quality durable cutters
- Excellent for use with kitchen worktop jigs
Axcaliber A5 Foam Router Cutter PresenterSpecial Price £4.30 £3.58 was £13.58 £11.32 Save £9.28 £7.73
When fitting kitchen worktops using a worktop jig, it is necessary for the router cutter to be long enough to extend below the bottom of the worktop but retain a sufficient length of shank in the router collet. This can be difficult to achieve with some routers and when you add an extension to the router such as a sub-base a long shank is needed to provide sufficient protrusion from the base. It's critical that the router bit is inserted to the K Line as moving away from the line causes instability. With this in mind we have introduced a worktop cutter featuring a longer shank than usually found on this type of cutter. This ensures you have enough reach to cut safely through the work piece. These cutters also feature a bottom cut insert for efficient plunge cuts. 50mm depth of cut, 12.7mm diameter and 107mm overall in length.
D = Overall Diameter | 12.7 mm (1/2") |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 51 mm (2") |
