Axcaliber Panel Mould Beading Cutters
- Use with guide bush and template for decorative panel work
- Produce ovolo or rounding over profiles on edges
- Twin flute cutters with plunge cut
- PTFE coating helps minimise resin build-up
- 1/4" shank
Trend Tool and Bit Cleaner - 532mlSpecial Price £14.78 £12.32 was £16.78 £13.98 Save £2.00 £1.67
Axcaliber A5 Foam Router Cutter PresenterSpecial Price £4.30 £3.58 was £13.58 £11.32 Save £9.28 £7.73
These twin flute cutters can plunge cut. With a guide bush fitted to the router and a template, they will produce decorative panel work on drawer fronts or cabinet doors. Used for edge moulding they produce ovolo or rounding over profiles.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
