From £23.75 £19.79
  • M42 high speed steel with 8% Cobalt welded to high strength spring steel alloy backing
  • Milled teeth ensure long life, fatigue resistant blade with HSS tooth tips.
  • High resistance to heat, abrasion, and vibration allows faster cutting rates
Customers Also Bought
Premium saw blades use M42 high-speed steel with 8% Cobalt which has been welded to a spring steel alloy backing. This results in a material that has a far greater resistance to heat and abrasion, allowing improved cutting performance in those materials that might have proved troublesome with a 'standard' blade. Many types of material can be cut with ease, all metals including hard steels when the blade is fitted to a slow running metal cutting bandsaw, or all timbers including abrasive timbers such as teak as well as man-made boards like mdf and chipboard when using a higher blade speed on a wood cutting bandsaw. M42 blades are so resilient that reclaimed timber presents no difficulties, as the blade will slice easily through the odd nail buried under the surface. N.B. Due to the possibility of stress fracture we do not recommend the use of these blades on wood cutting bandsaws with a wheel diameter of less than 12” (305mm). Blades are available in 1/2" x 6-10tpi & 10-14tpi, 3/4" x 4-6tpi & 10-14tpi.
  • Variable pitch teeth for a wider range of applications
  • Reduced sawing harmonics for quieter, reduced vibration cutting
  • Long life span of the blade
  • Cost per cut ratio is lower due to the much increased life and resistance to damage or fatigue
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
