Axcaliber T-Slot Cutter for Track Clamps
- Use to cut a T-slot in a workbench or an assembly table
- Enables use of guide rail clamps as hold-downs
- Produce custom-made guide rails in hardwood
- Cut a T-Slots in nylon for home-made
- PTFE coating helps minimise resin build-up
- 1/2" shank
Axminster 7 Piece Forstner Bit SetSpecial Price £25.48 £21.23 was £29.98 £24.98 Save £4.50 £3.75 -
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £16.45 £13.71 was £18.28 £15.23 Save £1.83 £1.52 -
Axminster Stainless Steel Metric Rule - 300mmSpecial Price £2.95 £2.46 was £3.28 £2.73 Save £0.33 £0.27 -
Axcaliber Ground Tooth Bandsaw BladesFrom £11.98 £9.98 was £11.98 £9.98 Save £0.00 £0.00 -
Axcaliber FineLine PTFE Coated HandsawFrom £12.31 £10.26 was £13.68 £11.40 Save £1.37 £1.14 -
Axminster Combination Square Metric 300mmSpecial Price £15.20 £12.67 was £17.88 £14.90 Save £2.68 £2.23
Looking like an overgrown keyhole cutter, you can use this cutter to cut a T-slot in a workbench or an assembly table. Once cut the T-slot enables you to use Axminster (or Festool) guide rail clamps as hold downs when working on a piece or gluing up. Alternatively a length of hardwood with a T-slot cut along its length can become a custom made or temporary guide rail. in addition, you can cut a T-Slot in nylon if making jigs to your own design. We suggest you remove the bulk of the waste with a straight cutter of the same diameter as the neck of the cutter (dimension E) prior to using the T-slot cutter.
Please note; When using this type of cutter it is recommended to use a small straight cutter first to remove some of the material and help prevent router overload.
| C = Width of Groove | 6.5 mm |
| D = Overall Diameter | 12.7 mm (1/2") |
| E = Minor Diameter | 8.7 mm |
| EAN Barcode | 5052511065011 |
| Shank Diameter | 1/2" (12.7 mm) |
| X = Depth of Cut | 23 mm |
- Standard Delivery* - £5
