Axcaliber Twin Flute Straight Cutter with Bottom Cut Insert - 1/2"(12.7mm)
- Heavy duty cutters with bottom cut insert
- Produced using advanced technology
- SAE4140 steel shanks hardened to Rockwell 45 HRC
- Diamond ground Sandvik micrograin tungsten carbide tips
- PTFE coating helps minimise resin build-up
- Produced with high shearing angles
- 1/2"(12.7mm) shank
Produced using advanced technology on up-to-the-minute multi axis CNC machinery. These heavy duty cutters have a bottom cut insert for a clean precise finish when making plunge cuts. Shanks made from SAE4140 steel hardened to Rockwell 45 HRC, renowned for its hardness and strength, and the tips are made from diamond ground micrograin tungsten carbide. A virtual mirror finish ensures a durable, clean cutter capable of holding a sharp edge and a thick TPTFE coating minimises resin build-up. All cutters are produced with high shearing angles.
Shank Diameter | 1/2" (12.7 mm) |
