From £283.38 £236.15
Low Stock
- get it Saturday 29th Jan, order within and choose Premium delivery. Delivery info
  • 150mm Rotary Table packaged with a tailstock and indexing plates.
  • 150mm(6") diameter
  • Four 11mm(7/16)" radial T slots
Customers Also Bought
Total:
£458.12 £381.77
An Axminster 150mm Rotary Table plus a tailstock and indexing plates for more advanced operations.
This 150mm(6") diameter rotary table with four 11mm(7/16") radial T slots and a No 2 Morse taper centre sleeve may be used in either horizontal or vertical positions. The centre height when used vertically is 100mm(3.94") and the table height in the horizontal position is 83mm(3.27"). The periphery of the table is finely marked in degrees and the collar on the operating handle, which drives the table through a 90:1 reduction wormgear, has a vernier scale which allows settings down to 20 seconds of arc. A very accurate and well made piece of equipment which will find a place in many a model engineer's workshop.
Axminster Rotary Table Tailstock
A substantially made tailstock with centre height adjustable over the range 80 to 110mm. The base size is 130 x 95mm and there are 15mm wide slots at the two ends for securing it to the machine table.
Indexing Plates for Rotary Tables
These indexing plates are used in conjunction with the rotary table to enable the table to be rotated by an exact fraction of a complete turn, a particular requirement when machining gears, sprockets, etc. on a vertical mill. There are three indexing plates in the set which together provide all the subdivisions up to 50 (although 28 and 44 carry very small errors). There are a further 26 subdivisions available between 51 and 100 plus others above 100. The spring loaded index pin locates positively in the holes in the index plates and the two brass setting plates help to keep count of the number of holes moved by the pin.
  • No 2 Morse taper centre sleeve
  • Horizontal or vertical mounting
  • Centre height 100mm(3.94") when vertical
  • Table height 83mm(3.27") when horizontal
  • 90:1 reduction wormgear
  • Axminster Rotary Table Tailstock
  • Substantial construction
  • Centre height from 80 to 110mm
  • Base size 130 x 95mm
  • Indexing Plates for Rotary Tables
  • All divisions up to 50 available except 28 and 44
  • Many more divisions up to 100
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPay By FinanceHitachi Pay by Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
