This powerful work light has 5W LED providing a strong, bright light. Power comes from either 2 x AAA batteries (not included) or by plugging directly into a mains or USB socket. The base features a strong magnet for quick location on any ferrous metal, such as a machine with a cast-iron table. Alternatively, a steel "C" clamp allows you to fix the light to the edge of a bench, work table or a shelf 65mm thick. The 400mm steel stem is highly flexible and holds the alloy lamp head exactly where you want it. The lamp itself can provide either a spot pool of intense light or, by simply adjusting the machined alloy hood, provide a softer broad illumination over a wider area. Simple to use, robust and very versatile, this work light is invaluable in any workshop. Supplied with a USB lead and 3 pin mains adaptor
Provides a powerful, intense spotlight or a widely diffused pool
Flexible stem, easy to bent into position, stays put
Operates on 3 x AAA batteries, 230V adaptor or USB
Magnetic base for use on machines or steel surfaces
Steel "C" clamp for benches or worktables up to 65mm thick
Provides a simple lighting solution to many workshop situations
