Axminster Professional 7 Bar Heavy Duty Roller Stand
501282
From £222.58 £185.48
9 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Thursday 17th Jul
  • A heavy duty 7 bar roller stand, maximum weight 800kg
  • Adjustable legs give a roller height of 665-1,060mm
  • Cast steel feet with 30mm adjustment for uneven floors
  • Rollers are 55mm in diameter, evenly spaced 305mm apart
  • Ideal to make an extention table for table saws or bandsaws
  • Can be joined together to make a conveyor system
  1. Axminster Professional 7 Bar Heavy Duty Roller Stand
Total:
£416.72 £347.27
This is a well made heavy duty roller stand able to take a load up to 800kg. The seven 55mm rollers are plated and have fine ribs for maximum strength. These are spaced 305mm apart and are mounted in 100mm x 40mm steel channels. The legs have telescopic inner sections and are adjustable to give a recommended roller height of between 665-1,060mm. Cast steel feet are fitted and these can be individually adjusted by up to 30mm to accommodate an uneven floor. This type of roller stand can be used as a extension to a woodworking table saw or bandsaw and is also able to take the weight of heavy stock used in metal fabrication works. Overall dimensions 2,050mm W x 470mm L. A very useful addition to most workshops.
4.00 9
