Hand operated arbor press which is very useful for assembling the brass tubes into the wooden blanks of the woodturning project kits. But, these have many other uses, such as rivetting, pressing eyelets, installing or removing bearings, etc. Punches, inserters, or other tools/dies may be added to the end of the ram depending on the desired task. Pressure is firm and uniform and the components are held square whilst being inserted. It has a travel of 114mm and a 19mm square arbor. 0.5 Tonne.
Axminster Engineer Series AP0 Arbor Press
| Model | AP0 |
| Arbor Size | 19 mm |
| Base Size | 241 mm x 102 mm |
| Max Stroke | 114 mm |
| Nett Weight | 8.5 kg |
| Overall Height | 250 mm |
| Arbor Size | 19mm |
| Stroke Length | 114mm |
| EAN Barcode | 5052511012398 |
