The Axminster Hard Wax Wood Repair Kit contains all you need to carry out professional repairs. The kit enables you to make scratches, dings, dents, gouges, chips or small holes disappear. With a little practice, damage to furniture, floors or worktops will be invisible in a matter of minutes. Hard wax is suitable for use in areas subject to regular daily use. The Repair Kit lets you repair damage to natural wood or laminate flooring. This kit is good value for money when compared to the alternative of a replacement. Only you will know where the repair is.
The wax is easy to use even for a deep repair. The applicator melts the wax to fill the damage. After a little levelling, graining and blending, the unsightly damage will have disappeared. With 20 pieces of hard wax filler you will be able to colour match any timber. The shade variations help in recreating the timber’s grain. The fine graining pens put the final touches to the repair before the blending pads and special repair lacquer spray finish the job.
Each kit consists of 20 hard wax sticks 40mm x 15mm x 13mm, applicator tool, levelling tool, 10 graining pens, blending pads, polishing pads, spray lacquer and instructions all in a tough storage case. Requires 3 x AA batteries.
Carry out professional repairs to unsightly damage
Bring floors, furniture, worktops back to former glory
Recreate timber grain for an almost invisible result
Kit contains everything you need
Scratches, holes, chips, dents, gouges will disappear
