The basis of most options for the Ultimate Edge is the Support Bar with Dual Axis Adjustment. This is machined from anodised alloy and bolts easily onto four pre-tapped threaded holes on the belt arm. This familiar round bar in ground silver steel allows Tormek jigs to be mounted. A clever system of sliding the bar in two directions in one operation is employed, locked with just a twist of a handle. The dual axis adjustment has graduations laser marked into the body so that consistent repeat settings can be made.
There is also a purpose-made Table (103843) and Honing Guide (105281) accessories to accompany this Support Bar with Dual Axis Adjustment
Made in Britain Yes
Intended Use Use Tormek jigs on the Ultimate Edge Sharpening System.
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 5052511094868
