PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
The AC1950B is a premium, compact bandsaw with many new features not normally found on machines of this size.
This bandsaw has a welded steel chassis with great strength designed into it. It has a generously sized cast iron table with a steel plate rear extension. The table mounting trunnions are unusually widely spaced, giving extra table support, but also ensuring that the table tilt is smooth in operation. A 19mm mitre fence slot is provided. The rip fence cam locks solidly to the front rail and is adjustable to the blade for accuracy. Twin scales allow the fence to be used either side of the blade.
The bandsaw uniquely has ceramic side and thrust blade guides; these give great blade support and are almost impossible to wear out. Once set, they stay set unless you change the width of the blade. A rack and pinion system adjusts the upper blade guide height.
The dust extraction is via two ports, one close to the bottom guides, the other in the lower wheel cabinet. An interconnecting hose means just one 63mm connection port needs coupling to a suitable vacuum extractor. There are twin blade speeds, giving flexibility for many jobs. A powerful induction motor with a multi V belt drives the bandsaw and is quiet and reliable.
Supplied with a steel leg stand with rubber feet and a UK made general purpose blade. There are a whole range of different blades available to suit any task. This could be the perfect bandsaw for the typical "shed-in-the-garden" hobbies and craft workshop.
Depth of cut: 135mm with 260mm width of cut
Compact machine of steel and cast iron construction
Upper and lower ceramic blade guides for long life and better blade control
Widely spaced table support trunnions, very smooth tilt action
Rigid, welded body construction allows high blade tension for increased accuracy
These products are designed and intended to be used in the home for light work and not for continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or education purposes.
3 Year Guarantee
