Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Craft AC21C 230V Compressor
Code: 104295
  • Small air compressor for the home workshop
  • 21L air receiver, 1.5kW motor
  • Oil lubricated pump for high reliability
  • Twin wheels and grab handle for easy mobility
  • Twin gauges to show receiver and outlet pressure
  • Suitable for many tasks in the home workshop
  • Show More
£149.95 (£124.96 Ex. VAT)
Out of stock - dispatch estimate is within 3 weeks.
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Axminster Craft AC21C 230V Compressor
  • Axminster Coiled Air Line - 7.5m
  • Axminster Heavy Duty Air Duster
  • Axminster 1/4"BSPT Male Bayonet Air Line Fitting
Total: £177.70
Description
In Detail
Craft Classification & 3 Year Guarantee
The AC21C is an economically priced air compressor for home use. It is fitted with a single cylinder oil lubricated pump with a 1.5kW high efficiency motor. The cast iron pump cylinder provides long term durability. Producing 5cfm @ 3 bar and 4cfm @ 6 bar compressed air delivery into a 21-litre air receiver. This compressor comes with wheels and a grab handle for easy mobility. Receiver and outlet pressure gauges are fitted along with an outlet pressure regulator.
It is suitable for a whole range of home workshop uses such as small size nailing and stapling, air riveting, dusting, tyre inflation, airbrushing and touch-up spraying. The only jobs which are beyond its capabilities are the use of the larger continuously running tools such as sanders, large spray guns, drills and polishers, all of which will need a more powerful compressor coupled to a larger capacity tank.
The outlet is fitted with a 1/4" BSP Euro style female quick release fitting.
Information Downloads
Promo
This product is on page 95 of the Axminster Tools & Machinery 2019/20 Catalogue.
A reliable and affordable compressor - ideal for the everyday tasks!
Your go to compressor for a whole range of arts and crafts, woodworking and general workshop tasks.
Perfect for airbrushing, touch-up spraying, doing small size nailing, stapling or just when you need to pump your car tyre.
In use with nailer / stapler
Oil level
Longlife and efficient cooling
The strong, durable cast iron pump cylinder provides excellent compressor strength and longlife. Plus, the ducted fan cooling system feature maintains a constant pump temperature for efficient cooling again increasing the compressors lifespan.
Easy to check oil level
The compressor is equipped with a sight gauge to make the daily task of checking the oil level easier.
Pressure gauges
In use checking tyre pressure
Tailor your output pressure
With separate gauges for the tank pressure and output pressure, it is easy to tailor the output pressure to your task requirement.
Protection against rust
The tank has been powered coated to help protect against rust. Plus, the easy to use water drain, makes it quick and simple to remove any water collected.
Specification
Specification
Duty Cycle 50%
Free Air Delivered 186.91 l/m (6.60 cfm) - @1 bar , 141.60 l/m (5.0 cfm) - @3 bar , 84.96 l/m (3.0 cfm) - @6 bar
Max Pressure 8 bar/116 psi
Model AC21C
Nett Weight 24 kg
Overall L x W x H 580 mm x 260 mm x 640 mm
Power 1.5 kW
Rating Hobby
Receiver Volume 21 litre
Sound Power Level [Uncertainty K] 86 dB(A)
Supply Requirements 230 V 1ph 13 A
Voltage 230 V
Plug Fitted UK 3 pin plug
Air Displacement 188 l/m (6.64 cfm)
Promo
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
