10% off Power Tools sale now on! Use code "POWER10" to save with this deal
From £419.98 £349.98
In Stock
- get it Tuesday 28th Sep, order within and choose Premium delivery. Delivery info
  • Medium sized radial bench pillar drill for home use, all cast iron construction
  • Smooth running 550W induction motor, 5 belt speeds 500-2,450 rpm
  • Spindle running in high quality ball bearings
Customers Also Bought
Total: £1,495.82
This is a truly universal drilling machine that will be an asset to any home workshop. Perhaps the most outstanding feature of the machine is the variable drilling width capacity of between 210mm and 420mm, measured from the centre line of the chuck to the front face of the column. This allows a maximum drilling width well above normal pillar drill capacity which, coupled with the ability to vary the drilling angle, gives the machine a high degree of versatility.
The horizontal movement of the head is controlled by a rack and pinion system which can be firmly locked in position. Tilting is easily achieved by undoing a locking knob at the top of the column, setting the required angle against a scale and re-locking the knob. There is a positive locating pin which runs in a keyway on the horizontal bar to ensure that the head returns exactly to the vertical. The 550W induction motor drives the drilling head, equipped with a 3-16mm keyless chuck through a V belt and a choice of 5 pulleys giving a speed range of (5) 500-2,450rpm.
In other respects this pillar drill is similar to the standard models, with a true running chuck spindle and a good fit of the quill assembly into the headstock casting to ensure consistent drilling. Fitted with rubber down feed grips, NVR switch, chuck guard and belt cover safety switch.
One word of warning: the chuck is located in the drive quill with the conventional Morse taper which requires an axial loading to keep it securely in place; if the head is used in the horizontal position together with a sanding drum or polishing mop, there is a risk of the chuck coming loose.
Please note: the morticing attachment is not suitable for this machine.
  • Quill assembly is a good fit into the headstock
  • Convenient rack and pinion table height adjustment
  • Fitted with soft grip rubber feed handles, and a quality 3-16mm keyless chuck
  • Features include belt cover safety switch and emergency stop switch
Warranty Craft Classification & 3 Year Guarantee
Buy with confidence
Machine Classification
These products are designed and intended to be used in the home for light work and not for continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or education purposes.
3 Year Guarantee
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPay By FinanceHitachi Pay by Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
