Update: Our Cardiff store is open. Stores in England remain closed, including their Click & Collect service. You can still order online for home delivery and contact our team of experts for advice. Standard delivery is 2-3 working days. For more information click here.
Black Friday Flash Sale - 15% OFF Selected Axminster Machinery ends in ... - Use code "MACH15" in the basket
£599.98 £499.98
In stock
- get it tomorrow, Wednesday 25th Nov, order within and choose Premium delivery. Delivery info
  • Heavy duty cast iron bed ensures minimal vibration
  • Cast iron headstock and tailstock
  • Quick release levers for easy positioning
Customers Also Bought
Total: £889.94
The AC355WL is a new design, perfect for those woodturners looking to move up from a smaller lathe, or as a first lathe for the more ambitious newcomer.
Like almost all top quality lathes, this one is made from grey cast iron. The extra stability and vibration absorbing properties will be much appreciated during use. Featuring a top quality DC brush motor, with variable speed, 3 belt ratios and reverse, it has a speed range to suit every project within its size capacities. A spindle speed readout helps select the appropriate speed for the job. The tailstock is angle towards the end of the bed, maximising the distance between centres, but is also extremely stiff. Cam locks secure both the tailstock and toolrest holder, and both are easy to move along the bed. The headstock is very smooth in design, with a projected nose for the back of the bowl turning, large bearings to support the spindle, and a flip-up cover allowing access to the gate's multi-V belt for speed ratio changing.
There is a system to provide a 24-stop indexing facility, with a spring-loaded indent pin to hold the spindle into position. The spindle thread is M33 x 3.5, allowing many accessories to be fitted, or use its 2MT internal taper to hold centres etc. With a capacity of 510mm between centres (depending on the centres fitted) and with a swing capacity of 355mm, many ambitious projects can be undertaken. Mounted on rubber feet and supplied with Axminster drive and tailstock centres, 200mm tool rest plus a 100mm faceplate.
  • Powerful 750W DC motor, quiet and smooth operation
  • Variable speed with spindle speeds from 250-3,550rpm
  • Hollow tailstock (9mm bore)
  • Tailstock barrel has 70mm of movement
This product is on page 323 of the Axminster Tools Catalogue 2020/21 View Page 323
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
