Before applying a surface finish to your bowls, it is desirable to leave a surface without any visible sanding marks. This can be difficult using normal methods and all too often, tell tale rings are left to spoil your best efforts for a perfect finish. One of the best ways of eliminating this problem is to use a rotating sanding pad driven by the rotation of the lathe. By working through different grit types starting with the coarsest and applying light pressure, you can achieve a surface well prepared for the finish of your choice. The Axminster Woodturning Deluxe bowl sanding kit contains two 70mm pads and two 50mm pads and a comfortable cushioned grip handle with an adjustable head for easy access to your work.
Axminster Woodturning Deluxe Bowl Sanding Kit
| Web Attribute Set | Woodturning Abrasives |
| EAN Barcode | 5052511046782 |
