Axminster Drill Guide Kit
SKU: 210235
€11,00 €12,00 Save €1,00
  • Guide for drilling accurately
  • Drill vertically on a flat, an edge or shaped surface
  • Vee groove on base for positioning
  • Clear plastic base and six hardened steel drill bushes
  • Metric; 4mm, 5mm, 6mm, 8mm,10mm and 12mm
Some of the best ideas are the simple ones. Combining a clear base with a vee groove and interchangeable steel bushes, this jig allows you to drill vertically and position it accurately on a flat surface or using the vee groove in the base on a corner, or centred on a cylinder or a sphere, both notoriously difficult shapes to drill into with any degree of accuracy. With metric bushes to suit drill sizes 4, 5, 6, 8,10 and 12mm.
Web Attribute Set Drilling Guides
EAN Barcode 5052511007448
