These 150mm width belt linishers are purpose-built for finishing or shaping metal components in fabrication workshops. Heavy and sturdy construction in welded plate steel, including the floor stand, gives these machines the strength required for heavy work all day long. You can either use the long, flat platter for flattening or the end roller for shaping; there is a hinged door guarding the platter when it is not in use. The linisher can be tilted on its stand using a simple hand lever for comfortable use. Belt changing is simple, just hinge down one side, release the tensioning lever and that's it. Work rests are provided, as is an eye shield. Twin extraction ports allow connection to a suitable extractor. Two versions are available: a 230V 1ph single speed and a 415V 3ph two speed model. The two speed model could also be used for sanding wood using suitable belts and a fine wood dust extractor,greatly enhancing the use of this version. N.B. These machines are designed to be bolted to the floor for stability. Supplied with an 80 grit belt.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Use for sanding/grinding items flat or for curved work
Easy to change sanding belts, tracking also easy to adjust
Twin dust extraction ports for efficient waste removal
Strongly made from welded steel plate, made to work every day
Powerful 3.0kW 230V 1ph or 2.8kW 415V 3ph motor, protected to IP54 standards
Machine Classification
