For our latest updates about delivery and stores, click here
£512.95 £427.46
In stock
- get it Tuesday 7th Jul, order within and choose Premium delivery. Delivery info
  • Engineering rated belt linisher, uses common 75 x 2,000mm belts
  • Can be used for sanding/grinding items flat or for curved work
  • Strongly made from welded steel plate, made to work every day
Customers Also Bought
Total: £521.85
These 75mm width belt linishers are purpose-built for finishing or shaping metal components in fabrication workshops. Heavy and sturdy construction in welded plate steel, including the floor stand, gives these machines the strength required for heavy work all day long. You can either use the long, flat platter for flattening or the end roller for shaping; there is a hinged door guarding the platter when it is not in use. The linisher can be tilted on its stand using a simple hand lever for comfortable use. Belt changing is a simple task, just hinge down one side, release the tensioning lever and that's it. Work rests are provided, as is an eye shield. Twin extraction ports allow connection to a suitable extractor. The CT-502H Extractor (508296) is recommended. N.B. This machine is designed to be bolted to the floor for stability, and we recommend that they are hard wired by a competent electrician.
  • Powerful 3.0kW 230V 1ph motor, protected to IP54 standards
  • Easy to change sanding belts, tracking also easy to adjust
  • Twin dust extraction ports for efficient waste removal
This product is on page 155 of the Axminster Tools Catalogue View Page 155
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
