Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The CT-502H is a purpose-built extractor for metal dusts. It has a unique air flow system that separates out the dust from the airflow to allow the various weights of metal particles to fall into either the large primary collection bin or a smaller secondary bin. A powerful 1.125kW 230V 1ph motor creates up to 1,360 m³/hr airflow through a choice of either a 150mm inlet or a pair of 100mm inlets. The impeller fan is an aluminium casting with efficient curved blades. The aluminium impeller construction prevents impact sparking from metal particles.The machine is heavily built and is mounted on castors for easy mobility. A large grab handle is fitted to make this an easy task. The three stage filters are mounted inside a drop down door, also giving access to the secondary collection bin. The main collection bin is mounted on rollers and is easily accessed through a large door. This machine would be a perfect partner for a metal grinding or linishing machines, suitable to use with ferrous metals, keeping your workshop and the operator clean. Heat resistant ducting hose is recommended, please see accessories.
N.B. requires a 16A supply
'Purpose built for ferrous metal dusts from metal grinding or linishing machines
Triple layer filtration including an active carbon layer
Special airflow characteristics separates waste from the airflow
Powerful 1.125kW induction motor and aluminium impeller
Castors and grab handle fitted for easy mobility
Large, easy-to-empty waste bin, large access doors
Machine Classification
This product is classified as a Large Delivery
product and will normally be delivered within 3-5 working days.
This is a Palletised Large Delivery service.
A specialised palletised goods carrier that will deliver to kerbside only.
The carrier will be in contact to confirm the delivery date.
UK Mainland - £60
UK Remote & Offshore* - charge advised in basket
