Low Price
Special Price £1,999.98 £1,666.65 was £2,399.98 £1,999.98 Save £400.00 £333.33
In Stock
- large delivery, normally within 3 to 5 working days. Delivery info
  • Built-in coolant system to prolong blade life and give a cleaner cut
  • 4 blade speeds, enables a speed to be chosen to suit the task
  • Double row ball bearing blade guides, holds the blade securely
Customers Also Bought
Total:
£2,370.72 £1,975.60
This metal cutting bandsaw is designed for use in fabrication and general engineering workshops. It is a swivelling head design which makes it easier to create accurate mitre cuts. Heavily built in cast iron to provide high strength and stability, it includes a floor stand with a built-in coolant system, mobility wheels and sealed electrical control box. The 750W 230V motor drives the blade through a 4-speed belt drive system, and is controlled by a convenient switch box mounted on the blade bow. An adjustable hydraulic damper controls the blade downfeed, with the machine being stopped automatically once the cut is completed. For batch cutting of components, a slip-in deflector tray will divert the cut item into a box placed next to the machine. The head and bow assembly swivels through 0° to 45° with indexing stops for each 15° increment. Coolant flow is controlled with a small valve mounted on the bow. This is a thoroughly well engineered machine that will suit many workshops, schools and colleges.
  • Fully adjustable downfeed hydraulic damper with gate valve
  • Whole arm/motor assembly swivels for accurate mitre cuts
Warranty Engineer Classification & 3 Year Guarantee
Axminster Engineer 3 Year Guarantee
Machine Classification
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    5.00 2
