PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
This fixed head metal cutting bandsaw is designed for use in fabrication and general engineering workshops. Heavily built in cast iron to provide high strength and stability, it includes a floor stand with a built-in coolant system, mobility wheels and a sealed electrical control box. The 750kW 230V motor drives the blade through a 4-speed belt drive system and is controlled by a convenient switch box mounted on the blade bow. An adjustable hydraulic damper controls the blade down feed, with the machine being stopped automatically once the cut is completed. Coolant flow is controlled with a small valve mounted on the bow. A quick action vice is fitted to make changing materials for the next cut a faster job. The blade guides are easy to adjust and a wire brush keeps the blade clean. A blade tension indicator is fitted to give an idea of where to set the blade. The rear part of the vice has two positions, the rear position used when creating bevel cuts. An accurate machine with good cutting capacities, perhaps best suited for square cutting to length using the built-in length stop. If you need to carry out very accurate bevel cuts, the 505215 UE-712SB would be better suited.
Double row ball bearing blade guides, holds the blade securely
4 blade speeds, enables a speed to be chosen to suit the task
Vice jaws swivel for bevel cuts, quick action jaws for fast clamping
Built-in coolant system to prolong blade life and give a cleaner cut
Fully adjustable down feed hydraulic damper with gate valve
Machine Classification
This product is classified as a Large Delivery
product and will normally be delivered within 3-5 working days.
This is a Palletised Large Delivery service.
A specialised palletised goods carrier that will deliver to kerbside only.
The carrier will be in contact to confirm the delivery date.
UK Mainland - £60
UK Remote & Offshore* - charge advised in basket
