Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Engineer Series UE-916A Bandsaw
Code: 508333
  • A rugged machine for fabrication and general engineering workshops
  • 4 blade speeds, enable a speed to be chosen to suit the task
  • Double row ball bearing blade guides, hold the blade securely
  • Built-in coolant system to prolong blade life and give a cleaner cut
  • Fully adjustable downfeed hydraulic damper with setting control
  • Vice jaws swivel for bevel cuts, quick action jaws for fast clamping
  • Show More
£2,549.50 (£2,124.58 Ex. VAT)
Low stock - heavy goods delivery within 7-21 working days
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
Heavy Goods
  • UK mainland - free
  • UK remote - charge advised in basket
This bespoke service includes off-loading and assistance where practical. Our delivery experts will contact you to arrange a convenient delivery date.
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Axminster Engineer Series UE-916A Bandsaw
  • Ambersil Tufcut Aqua Cutting Fluid
  • Axcaliber Premium Bandsaw Blade 3,035mm(119") x 27mm 10-14 Tpi
Total: £2,672.10
Description
In Detail
Engineer Classification & 3 Year Guarantee
The UE-916A metal cutting bandsaw is robust and quite compact for the cutting capacities. It is suitable for use in fabrication workshops, engineering workshops and general factory use. The chassis and arm are stiff cast iron giving great strength and accuracy in the cut, whilst the welded steel base houses a coolant pump system and the electrical controls. The 1.1kW motor drives the blade through a choice of 4 speeds for a wide range of cutting tasks. The cutting bow has a hydraulic down feed control ram with a feed rate selection dial and lock off control mounted on the switch panel. A comprehensive guide system holds the blade securely so that accurate cuts are made every time. A blade tension indicator is part of the tensioning system for accurate tension setting. The vice has a clever setting latch plus the rear jaw can be swivelled for bevel cuts. Safety interlock switches prevent the machine being run whilst the blade access doors are open. Coolant is supplied to both sets of guides, the flow rates can be set using the lever valves. This is a well engineered machine that will do the job every day.
Information Downloads
Promo
This product is on page 158 of the Axminster Tools & Machinery 2019/20 Catalogue.
Axcaliber CutPro Circular Saw Blades
We are committed to giving you the ultimate experience from your bandsaw.
Which is why we only recommended the finest blades to be used with them. All of our Premium blades are made in Axminster, using M42 high speed steel with 8% cobalt. All types of materials can be cut with ease and will ultimately last longer.
Specification
Specification
Bandsaw Blade Length 3,035 mm (119.1/2")
Blade Speed 24, 40, 51 & 71 m/min
Blade Width 27 mm
Max Cap Rectangular 225 mm x 345 mm / 35 mm x 400 mm
Max Cap Round 225 mm
Max Cap @ 45º 165 mm x 225 mm or 165 mm round
Model UE-916A
Nett Weight 285 kg
Overall L x W x H 1,727 mm x 749 mm x 1,092 mm
Power 1.1 kW
Rating Engineer
Voltage 415 V
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
