Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Engineer Series UV-180DS Bandsaw
Code: 103629
  • A rugged machine for general engineering workshops
  • Variable blade speed, offers the right speed for the task
  • Double row ball bearing blade guides hold the blade securely
  • Built-in coolant system to prolong blade life and give a cleaner cut
  • Fully adjustable downfeed hydraulic damper with gate valve
  • Whole arm/motor assembly swivels for accurate mitre cuts
  • Vice slides across for full material support on mitre cuts
  • Show More
£1,739.50 (£1,449.58 Ex. VAT)
Low stock - get it tomorrow, Saturday 6th Jun, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (3-5 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Axminster Engineer Series UV-180DS Bandsaw
  • Ambersil Tufcut Aqua Cutting Fluid
  • Axminster 7 Bar Heavy Duty Roller Stand
Total: £2,007.58
Description
In Detail
Engineer Classification & 3 Year Guarantee
This metal cutting bandsaw is designed for use in small fabrication and general engineering workshops. It has a swivelling head design which makes it easier to create accurate mitre cuts. Heavily built in cast iron to provide high strength and stability, it includes a floor stand with a built-in coolant system.
The 750W 230V motor drives the blade through a direct drive variable speed system and is controlled by a convenient switch box mounted on the blade bow. An adjustable hydraulic damper controls the blade downfeed, with the machine being stopped automatically once the cut is completed. A selector switch allows hand control via a switch mounted on the bow, useful for starting or making delicate cuts. The variable speed drive gives a great flexibility of use over many materials and takes the effort out of changing speeds, making the blade last longer.
The head and bow assembly swivels through 0° to 45° L and 0°-60°R with a scale and locking clamp. Cleverly, the vice slides across to give full material support for cutting precise angles. Coolant flow is controlled with a small valve mounted on the bow.
This is a thoroughly well engineered machine that will suit many workshops, schools and colleges.
Information Downloads
Promo
This product is on page 158 of the Axminster Tools & Machinery 2019/20 Catalogue.
Axcaliber CutPro Circular Saw Blades
We are committed to giving you the ultimate experience from your bandsaw.
Which is why we only recommended the finest blades to be used with them. All of our Premium blades are made in Axminster, using M42 high speed steel with 8% cobalt. All types of materials can be cut with ease and will ultimately last longer.
Specification
Specification
Bandsaw Blade Length 2,285 mm (90")
Blade Speed 35 to 85 m/min (var)
Blade Width 19 mm
Max Cap Rectangular 165 mm x 230 mm
Max Cap Round 180 mm
Max Cap @ 45º 140 mm x 150 mm or 140 mm round
Max Cap @ 60º 90 mm Round
Model UV-180DS
Nett Weight 116 kg
Overall L x W x H 1,258 mm x 585 mm x 1,296 mm
Power 750 W
Rating Engineer
Voltage 230 V
Plug Fitted UK 3 pin plug
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
