Axminster Woodturning Micro Handle
106781
From £14.98 £12.48
  5. Half Star
10 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Wednesday 28th May
  • Machined from a solid stainless steel bar
  • Perfect for turning pens and small projects
  • Comfortable contoured grip with light knurling
  • 7.5mm bore to accept a range of turning tool blades
  • Tools lock securely with two grub screws
  • Weight keeps the tool on the rest
  • Easy to maintain a high level of control
  • Size 150mm long x 25mm diameter
The perfect tool for precision work
Designed for pen and project work, the stainless steel handle features a contoured grip with light knurling, designed to give you maximum comfort and control when you turn.
Made exclusively for Axminster Woodturning
Choose between a variety of tools; each one fits directly into the Micro Woodturning Handle
Crown Gouge
The shallow flute is perfect for cutting coves and beads.
Crown Skew Chisel
Use for fine planing cuts, rolling beads and cutting vee grooves.
Crown Parting Tool
The ideal tool for parting off or sizing.
Crown Spiralling and Texturing Tools
Add a variety of decorations and patterns to your turned work.
Set of 6 Crown Tools
This set is perfect for miniature and intricate work.
  • Round nose scraper - clean inside bowls and coves
  • Swan neck scraper - reach difficult areas
  • Diamond side scraper - finish the bottom of boxes
  • Round side scraper - for undercutting
  • 6mm skew chisel and 6mm spindle gouge - for intricate work
  1. Axminster Woodturning Micro Handle
Total:
£167.02 £139.18
The Axminster Woodturning Micro Handle is another piece of precision engineering from our own manufacturing facility in Axminster. Machined from a solid stainless steel bar it has a gently contoured grip with light knurling to prevent it slipping in the hand.
The business end has a 7.5mm bore to accept a range of small and miniature turning tools as well as other accessories. The tools lock securely into place with two grub screws.
The Axminster Woodturning Micro Handle provides plenty of mass which we have found a great advantage when turning. The weight helps you keep the tool on the rest and maintain the high level of control required for small and miniature work. Perfect for turning pens and small projects. Size 150mm long x 25mm diameter with 7.5mm bore.
British Made British Made
4.70 10
