Axminster Bush For CBN Wheels - 5/8" Bore (Pair)
104372
In stock
- Precisely CNC machined reducing bush
- To fit Axminster CBN grinding wheel
- Allows fitting CBN wheel to bench grinders with a 5/8" shaft
Customers Also Bought
This precisely CNC machined reducing bush is made to take the bore diameter of an Axminster CBN grinding wheel down to 5/8" in order to fit the CBN wheel to a bench grinder with a 5/8" diameter shaft. If fitting a CBN wheel to the AC200WSG (105842) use bush number 106660.
- If fitting a CBN wheel to the AC200WSG (105842) use bush number 106660
