These centres are safe, secure and offer greater versatility and accuracy than the more common 2 or 4-prong drive centres. Being made entirely of stainless steel they will not rust or corrode when used with green timber or left in an unheated workshop.
The centre features a spring loaded, stainless steel centre point, with a sharp toothed outer ring providing the drive. The Pro Drive is unique in that you can vary the spring tension. There are numerous advantages when using this drive. Repositioning your work is accurate; the work always goes back in the same place. They are safe; reduce the pressure from the tailstock and in the event of a dig-in the work will simply stop revolving. Reducing the tailstock pressure further allows you to stop the work and inspect it without switching off the lathe. In production, the centre allows unloading and reloading by unwinding the tailstock without stopping the lathe. When used for eccentric turning, the centre will still drive even if its full diameter is not in contact with the work. Being made entirely of stainless steel they will not rust or corrode when used with green timber or left in an unheated workshop.
Available in 1MT or 2MT.
N.B. The head diameter measurement is taken from the diameter of the teeth points where initial contact is made.
Made in Britain Yes
Morse Taper 2 MT
Head Diameter 21 mm
Intended Use Plays a crucial role in securely holding the workpiece on a lathe.
Web Attribute Set Drive Centres
EAN Barcode 5052511064519
