Axminster Woodturning
Axminster Woodturning Faceplate 100mm - M33 x 3.5mm
SKU: 500125
€40,00
  • 100mm diameter faceplate
  • Maximum accuracy and perfect balance
  • Circular grooves aid blank centring
  • Thread size M33 x 3.5mm
100mm diameter faceplate is CNC-produced for maximum accuracy and perfect balance. The timber mounting holes are fully countersunk on the rear face and lightly countersunk on the front face to ensure proper seating of the timber; circular grooves are provided to aid the centring of the blank on the plate.
Made in Britain Yes
Thread Size M33 x 3.5mm
Intended Use Plays a crucial role in securely holding the workpiece on a lathe.
Web Attribute Set Faceplates
EAN Barcode 5052511022205
