£199.98 £166.65
Out of Stock
- stock due in 12 weeks. Delivery info
  • 'A' frame stand which when open is very stable
  • Designed for smaller basic tasks; ideal for smaller routing tasks
  • Top and frame folds flat so easily portable for site work
Customers Also Bought
Total: £269.72
For those with limited space in the workshop or for use on site, this folding, compact, lighter-duty router table will be particularly convenient. Designed for smaller basic tasks, it is ideal for smaller routing tasks. The principal feature is the folding stand made from heavy gauge steel section with a black powder coated finish. The rear leg assembly opens to form a rigid 'A' frame that will close flat. The router table top can also be turned so that it folds flat against the frame with the result that the complete table can be stored against a wall taking up the barest minimum of space in a smaller workshop. The router table, complete with a phenolic resin insert plate with two rings, measures 604 x 400mm and is screwed directly to the folding stand. Standard 19mm aluminium 'T' track is fitted into the table top for an optional mitre gauge. The fence is made from a rigid steel back plate and uses a pair of aluminium alloy 'T' tracks incorporating metric scales meaning that it can be precisely located on the table surface. A pair of adjustable extruded aluminium in and out-feed fences can be opened and closed allowing the use of a wide range of cutters (not recommended for panel raising or large cutters). A clear plastic safety shield is included as well as a 37mm extraction port at the rear that has an additional 63mm adaptor.
  • Small footprint for storage
  • Excellent lighter-duty router table where space is limited
  • Height (including the router table) of 830mm, table size 604x400mm
  • Phenolic resin insert plate with 105mm and 72mm diameter rings
  • 19mm aluminium ‘T’ track
  • 'T' tracks each with a metric scale for the fence
  • Adjustable in and out-feed fences
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
