WeCheer Flexi-Shaft Pendant Drive
- Intended for the serious carver, modeller or pattern maker
- 190W continuously rated motor
- Variable speed (0-20,000rpm) controlled by foot pedal
Customers Also Bought
A heavy duty flexible shaft pendant drive for the serious carver, modeller or pattern maker, powered by a 300W input - 150W output, continuously rated motor. The speed is variable over a range of 0-20,000rpm and is controlled by means of a convenient foot pedal. The 970mm long flexible shaft screws firmly onto the base of the motor and carries a plug-in bayonet on the other end for connection to any one of the optional handpieces or reciprocating carving head which are not supplied and need to be purchased separately.
- 970mm long flexible shaft
- Wall mounted hanger
- Not supplied with handpieces
- Choice of handpieces and 1 carving head available
