Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Trade AT355PS26 OHCG Panel Saw
Code: 104248
  • Precision ground cast iron main table
  • 2,600 x 360mm heavy duty sliding table with large panel support carriage
  • Takes 305 or 355mm main saw blades
  • Separately powered, fully adjustable 120mm scoring blade
  • Outfeed and side extension tables standard
  • Cast iron rip fence body with fine adjustment
  • Comprehensive overhead crown guard provides added safety and dust extraction
  • Show More
Save £431.50
Last Few
NOW £4,968.00
Normally £5,399.50
(£4,140.00 Ex. VAT)
Low stock - heavy goods delivery within 7-21 working days
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
Heavy Goods
  • UK mainland - free
  • UK remote - charge advised in basket
This bespoke service includes off-loading and assistance where practical. Our delivery experts will contact you to arrange a convenient delivery date.
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Trade Classification & 3 Year Guarantee
This is a great mid sized heavy duty panel saw designed for ease of use and the high accuracy cutting of board materials of all types.
Offering a full 2,500mm before the blade, the heavy duty 2,600 x 360mm sliding table is robust and smooth running. A panel frame supports the larger boards and a mitre fence with extension plus 2 length stops is standard. There are plenty of adjustments that can be made to ensure accuracy, but these saws and sliding tables are matched and factory set.
Unusually, the saw has a choice of main blade size, either 305 or 355mm giving a maximum depth of cut of 110mm at 90°. A 120mm scoring blade powered by a separate motor is standard, giving the finest of scoring cuts on faced materials, preventing chipping of the edge of the cut.
The main table is a rigid, precision ground, cast iron surface of 548 x 896mm supported by a welded steel chassis, powder coated for long term protection. A cast iron rip fence body with fine width adjustment is complemented by a long, alloy extrusion fence arm, all running on a solid 40mm diameter chromed steel rail. Rear outfeed and side extension tables in thick gauge sheet steel are standard, along with a work clamp, handle and edge shoe for the sliding table.
As you can use blades up to 355mm in diameter, the overhead crown guard is included as standard; also included is a riving knife for 355mm blades. The overhead crown guard is much safer in use and gives much better dust extraction.
A 96T fine cross cut blade main saw blade from our Axcaliber Premium blade selection is supplied.
This is a simple, reliable and accurate panel saw, easy to use and an asset in many workshop situations.
Please ensure that your workshop electricity supply is adequate for these machines. If unsure, seek advice from a qualified electrician. N.B. 32A supply is required, (5 pin, 3 x L, N + E for 415V supply).
This machine was previously known as the P305/2600.
Promo
This product is on page 17 of the Axminster Tools & Machinery 2019/20 Catalogue.
Specification
Specification
Blade Diameter 305 mm or 355 mm
Blade Tilt 0° to 45°
Bore Size 30 mm
Dust Extraction Outlet 100 mm & 120 mm
Max Ripping Width 1,300 mm
Max Width of Cut with Fence 1,300 mm
Min Extraction Airflow Required 2,000 m³/hr
Model AT355PS26
Nett Weight 582 kg
Number of Motors 2
Overall L x W x H 2,550 mm x 2,624 mm x 1,321 mm
Power 3.75kW
Rating Trade
Scoring Blade Bore 20 mm
Scoring Blade Diameter 120 mm
Sliding Table Dimensions 2,600 mm x 360 mm
Sliding Table Stroke 2,500 mm
Table Height 875 mm
Table Size 548 mm x 875 mm
Voltage 415 V
Plug Fitted UK 32A Plug
Max Depth of Cut @ 45º 63 mm with 305 mm blade - 75 mm with 355 mm blade
Max Depth of Cut @ 90º 110 mm with 355 mm blade - 90 mm with 305 mm blade
Blade RPM 4,000 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
