For our latest updates about delivery and stores, click here
£5,839.50 £4,866.25
Out of stock
  • Precision ground cast iron main table
  • 3,200 x 360mm heavy duty sliding table with large panel support carriage
  • Takes 305 or 355mm main saw blades
Customers Also Bought
This is a great mid sized heavy duty panel saw designed for ease of use and the high accuracy cutting of board materials of all types.
Offering a full 3,100mm before the blade, the heavy duty 3,200 x 360mm sliding table is robust and smooth running. A panel frame supports the larger boards and a mitre fence with extension plus 2 length stops is standard. There are plenty of adjustments that can be made to ensure accuracy, but these saws and sliding tables are matched and factory set.
Unusually, the saw has a choice of main blade size, either 305 or 355mm giving a maximum depth of cut of 110mm at 90°. A 120mm scoring blade powered by a separate motor is standard, giving the finest of scoring cuts on faced materials, preventing chipping of the edge of the cut.
The main table is a rigid, precision ground, cast iron surface of 548 x 896mm supported by a welded steel chassis, powder coated for long term protection. A cast iron rip fence body with fine width adjustment is complemented by a long, alloy extrusion fence arm, all running on a solid 40mm diameter chromed steel rail. Rear outfeed and side extension tables in thick gauge sheet steel are standard, along with a work clamp, handle and edge shoe for the sliding table.
As you can use blades up to 355mm in diameter, the overhead crown guard is included as standard; also included is a riving knife for 355mm blades. The overhead crown guard is much safer in use and gives much better dust extraction.
A 96T fine cross cut blade main saw blade from our Axcaliber Premium blade selection is supplied.
This is a simple, reliable and accurate panel saw, easy to use and an asset in many workshop situations.
Please ensure that your workshop electricity supply is adequate for these machines. If unsure, seek advice from a qualified electrician. N.B. 32A supply is required, (5 pin, 3 x L, N + E for 415V supply).
This machine was previously known as the P305/3200.
  • Separately powered, fully adjustable 120mm scoring blade
  • Outfeed and side extension tables standard
  • Cast iron rip fence body with fine adjustment
  • Comprehensive overhead crown guard provides added safety and dust extraction
This product is on page 17 of the Axminster Tools Catalogue View Page 17
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
