Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Trade AT940DDS Dual Drum Sander
Code: 501277
  • Plenty of power and robust construction for production sanding
  • Abrasives can be quickly changed, secure wedge type clamps
  • Micro adjustment of rear drum for setting to different abrasive grades
  • 4" or 102mm abrasives strips should be used
  • Hard rubber coated drums for accurate sanding
  • Conveyor table supported by 4 screw posts
  • 2-speed gearbox on conveyor to accommodate differing timbers
  • 2 x 100mm dust ports for efficient extraction
  • Compact design takes up little valuable workshop space
  • Show More
£4,699.96 (£3,916.63 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
Heavy Goods
  • UK mainland - free
  • UK remote - charge advised in basket
This bespoke service includes off-loading and assistance where practical. Our delivery experts will contact you to arrange a convenient delivery date.
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Axminster Trade AT940DDS Dual Drum Sander
  • Abranet Max Abrasive Roll 101mm x 25m 120g
  • Hermes RB 346 J Flex 25m x 75mm Abrasive Roll 120 Grit
  • Jet OES-80 CS Oscillating Edge Sander
Total: £5,819.99
Description
In Detail
Trade Classification & 3 Year Guarantee
The AT940DDS twin drum finishing sander is the heavyweight of the range and is intended for the busy professional workshop where usage is more frequent and more arduous. N.B. These sanders are used for the final finishing process, they are not intended to be used as a thicknesser or with coarse abrasive for significant stock removal. In all instances, they are intended to be used with planed and thicknessed material.
The construction of the machine is predominantly of heavy gauge steel sheet, the 150mm diameter rollers are precision machined from aluminium castings and the power is supplied by two motors, 5.5kW(415V, 3ph) for the sanding drum drive and a 190W for the conveyor belt drive.
In use, the two drums are loaded with different grades of abrasive, coarse fitted to the front drum and fine on the rear and there is a choice of abrasive available to suit the type of timber being used and the finish required. The abrasive comes in 100 or 75mm wide strips and is wound spirally around the drums and securely held by wedge clamps. There is a very accurate setting system for the rear roller to allow easy adjustment to accommodate different grades of abrasive. The timber is held in contact with the conveyor belt by three pressure rollers. This arrangement ensures that the work is held in close contact with the conveyor belt, giving safe operation and a uniform thickness to the finished work. A two speed conveyor drive gearbox gives a greater range of finishes and eases the load on the machine. The conveyor belt is of non-marking rubber.
A full width stop bar, mounted on the front of the machine can be reached from almost any position and enables the machine to be stopped quickly when required.
The machine will handle timber thicknesses between 1mm and 133mm and the adjustment is via a handwheel conveniently situated on the top of the machine. A digital read-out scale allows accurate settings to be made, either for the first pass or just a minute tweak for the final finishing pass. Twin 100mm dust ports are provided, efficient dust extraction is vital to the performance of this machine, please make sure that your dust extraction system is adequate. A solid and dependable machine which will rapidly repay its investment in a busy workshop where high volume throughput is the order of the day.
Please ensure that your workshop electricity supply is adequate for these machines. If unsure, seek advice from a qualified electrician. N.B. 16A socket supply is required, (5 pin, 3 x L, N + E for 415V supply).
This machine was previously known as the R3409.
Information Downloads
Promo
This product is on page 74 of the Axminster Tools & Machinery 2019/20 Catalogue.
Specification
Specification
Abrasive Roll Width 102 mm
Dust Extraction Outlet 2 x 100 mm
Feed Speed 2 m/min or 3 m/min
Model AT940DDS
Nett Weight 440 kg
Overall L x W x H 1,090 mm x 1,420 mm x 1,090 mm
Power 5.5 kW
Rating Trade
Sanding Drum Diameter 152 mm
Sanding Thickness Min\Max 1 mm to 133 mm
Sanding Width Single Pass 940 mm
Voltage 415 V
Plug Fitted UK 16A Plug
Drum Speed 1,500 rpm
Min Extraction Airflow Required 1,500 m³/hr
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
