Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Trade AT3086B Bandsaw
Code: 103472
  • Steel and cast iron construction, tough and highly durable
  • Cast iron table and balanced, cast iron wheels
  • High blade speed, copes with all types of woods
  • Powerful, smooth running, electro-mechanically braked induction motor
  • Heavy duty blade guide bearings throughout
  • 2 x 100mm dust outlets for excellent dust control
  • Quick release blade tensioning lever, speeds up blade changing
  • Show More
£1,929.50 (£1,607.92 Ex. VAT)
In stock - heavy goods delivery within 7-21 working days
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
Heavy Goods
  • UK mainland - free
  • UK remote - charge advised in basket
This bespoke service includes off-loading and assistance where practical. Our delivery experts will contact you to arrange a convenient delivery date.
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Axminster Trade AT3086B Bandsaw
  • Axcaliber Freshcut 37 GT Bandsaw Blade 3,086mm(121.5") x 19mm 3 Tpi
Total: £1,946.20
Description
In Detail
Trade Classification & 3 Year Guarantee
This bandsaw may be compact in size, but packs a real punch with an unrivalled 14" cutting depth capacity. Being part of our Axminster Trade range you can be sure of its build quality and strength.
Manufactured in thick gauge welded steel and cast iron to a very high standard, the AT3086B is fitted with a key released emergency stop switch and safety interlocked doors for safe operation. There is a convenient tool and accessory storage cupboard in the lower half of the chassis.
The upgraded electro-magnetically braked motor is robust, smooth and powerful enough for all workshop tasks. Features include balanced, cast iron wheels, heavy duty bearing blade guides throughout, and a very rigid, full size cast iron table with tilt adjustment of -5° to +45° carried out by a rack and pinion mechanism for ease of adjustment.
Blade changing is made easy with a quick release blade tensioning lever which speeds up the blade changing process greatly. The rip fence has a cast iron bracket and features a tall fence rail, which can also be fitted in a different position to allow thin work to be guided properly. A cam lock clamps the fence to the guide rail securely and there is a magnifying lens to make the scale easy to read. The included mitre fence is a precision unit, fitted with an indexed position stop pin for easy and precise angle setting. Dust extraction is via 2 x 100mm ports, enabling dust-free use when connected to a suitable extractor.
This machine offers the ideal solution for the larger workshop or educational facility at an economical cost. This upgraded bandsaw is fully compliant with both the requirements of BS 4163:2014 (educational establishments) and PUWR98 (workplace) regulations. This model will also appeal to those requiring the very highest safety and performance standards in their workplace. Supplied with a 3/8" x 6 tpi bandsaw blade.
This machine was previously known as the SBW-3501H3.
Information Downloads
Promo
Specification
Specification
Bandsaw Blade Length 3,086 mm (121.1/2")
Bandsaw Wheel Diameter 355 mm
Blade Speed 720 m/min
Blade Width Min\Max 3 mm to 19 mm
Dust Extraction Outlet 2 x 100 mm
Max Cutting Height 356 mm
Max Width of Cut 342 mm
Max Width of Cut with Fence 315 mm
Min Extraction Airflow Required 1,500 m³/hr
Model AT3086B
Nett Weight 145 kg
Overall L x W x H 740 mm x 825 mm x 1921 mm
Power 1.5 kW
Rating Trade
Sound Power Level [Uncertainty K] 100.1 dB(A)
Sound Pressure Level [Uncertainty K] 83 dB(A)
Table Height 940 mm
Table Size 552 mm x 410 mm
Table Tilt 5° - 0° - 45°
Voltage 230 V
Plug Fitted UK 3 pin plug
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
