Axminster Trade AT400SB 400mm Saw Bench
- Substantial ground cast iron table gives a large, stable working surface
- Mechanically braked, high efficiency, 3ph induction motor
- Rigid cast iron rip fence body with cam action clamps and long fence rail
Customers Also Bought
This saw is a larger version of our TSCE-12R table saw, having the same basic design whilst remaining quite compact in size and being extremely robust. Available as a basic rip saw model, this machine is constructed around a heavy gauge welded steel chassis with a heavily braced cast iron table of very generous proportions. The 5.6kW 415v 3ph motor drives the 400mm blade giving ample power even at the maximum 130mm depth of cut. There is a 680mm width of cut from blade to fence, the rip fence being a heavy cast iron base running on a solid steel bar with fine width adjustment and a deep section alloy extrusion sliding fence rail. Fitted with cam lock clamps, this fence will remain in place even under arduous cutting conditions. A heavy duty cast iron mitre fence running in a T slot is provided.
There is a full overhead crown guard provided for full blade protection, complete with excellent provision for dust extraction. The saw motor/arbor frame is a massive casting providing rigidity and vibration damping qualities, all adjustments to the blade height and tilt being made by the extra large cast iron hand wheels. The hand wheels also have built in locking facilities to prevent movement of the blade from the settings made, and are exceptionally smooth in operation. A conveniently situated switch box has a locking emergency stop button, features overload protection and individual phase fuses. A separate foot operated emergency stop switch is conveniently situated to provide extra operator safety. Supplied with a 400mm diameter, 36T rip blade. An ideal saw for producing large frames for roofing, joists, gate posts or processing other heavy timbers.
Also available is a large right hand extension table, complete with a longer rip fence rail and extension to the overhead crown guard. This will give up to 1,175mm width of cut from blade to fence. There is also a lower storage platform for materials etc.
A simple sliding table kit is also available, comprising of an alloy extrusion sliding table, and a cross cut table with a telescopic support leg. This is easy to fit, fully adjustable and will give 1,360mm before the blade. It also has a mitre fence rail with a flip over length stop.
N.B. 415V 3ph only
- Blade rise and fall plus tilt via smooth acting locking cast iron hand wheels
- Full electrical overload protection and emergency stop switch provision
- Additional options are available to enhance this machine for different jobs
