Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Axminster Large Drum Sander
Code: 500184
  • Suitable for vertical mounting in drill press or drill stand
  • Can also be mounted on the lathe producing an excellent contour sander
  • Uses 150mm wide abrasive strip
£31.36 (£26.13 Ex. VAT)
In stock - get it Tuesday 9th Jun, order within and choose Premium delivery
  • Save 20% - Buy 10 for £25.08 each
  • Save 25% - Buy 50 for £23.52 each
  • Save 35% - Buy 100 for £20.38 each
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (3-5 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Axminster Large Drum Sander
  • Axminster Abrasive Belt Cleaner - Standard (210 x 40 x 40)
  • Axminster Sleeveless Sanding Drum 25mm x 75mm
  • Axminster Unigrip Vertical/Horizontal Drill Vice - 100mm
Total: £95.78
Description
In Detail
Following on the success of the drum sander bobbin set we have sourced this king size bobbin with which to make your own sanding devices. Mounted vertically in a drill press or drill stand it makes, with the addition of some simple woodwork, an excellent bobbin sander. Alternatively, mounted onto the end of a small motor or in the lathe, an excellent contour sander with endless applications. The bobbin uses 150mm wide abrasive strip, held and tensioned in place with an elliptical locking key. Size 75 x 150mm, supplied with 100g loading and 12.7mm(1/2") male shaft (held in place with a grub screw) which may be withdrawn leaving a 16mm(5/8") hole 31.75mm(1.1/4") long - suitable for most small 230V motors. N.B Maximum rotational speed is 1,500rpm.
Promo
This product is on page 315 of the Axminster Tools & Machinery 2019/20 Catalogue.
Specification
Specification
Abrasive Grit 100
Abrasive Type Aluminium Oxide
Shank Diameter 1/2" (12.7 mm)
Bobbin Height 150 mm
Bobbin Diameter 75 mm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
