Axminster Engineer Series Magnetic Base
600401
From £16.58 £13.82
  5. Half Star
8 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 24th Jun
  • Rigid 12mm diameter centre post
  • Solidly mounted cross bar with spring-loaded adjustment system
  • Universal fitting
  • Mounting fitting can be rotated through 360°
  • Allows for a choice of mounting positions
  1. Axminster Engineer Series Magnetic Base
Total:
£66.32 £55.27
This magnetic base has a rigid 12mm diameter centre post and a very solidly-mounted cross bar with an ingenious spring-loaded adjustment system for varying the height of the dial indicator. The universal fitting on the end of the arm will take the standard 8mm stems of our various dial gauges as well as having the facility to mount an indicator with a lug on the back. The mounting fitting can be rotated through 360° in two planes to give maximum flexibility in positioning the indicator. The base is machined on the bottom and one vertical side to allow for a choice of mounting positions.
4.30 8
