Axminster Woodturning Matched Pair of Ring Centres
- Matched pair or ring centres; Drive centre and Live centre
- Enables work piece to be swapped end for end for better access
- Eliminates risk of splitting thinner sections of timber
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price £69.97 £58.31 was £89.98 £74.98 Save £20.01 £16.67
Using a Ring Friction Drive in conjunction with a Ring & Centre Point Live Centre allows you to swap your work end for an end. The business ends of both centres match exactly, preserving concentricity. This will give you better access to your work in a variety of situations. These are safer to use if you are a newcomer to woodturning. If you experience a dig in, the workpiece simply stops rotating. The drive centre works by friction so the amount of compression on the work can be adjusted to suit your needs. Ring centres eliminate the risk of splitting small section or brittle timber.
