Designed for precision and ease on smaller projects, the Axminster Mini Bar Clamp/Spreader is a compact, reliable extra pair of hands in the workshop. Available in two practical sizes, 150mm x 60mm and 300mm x 60mm, it delivers controlled clamping or spreading with a simple one-handed action, making it ideal for assembly, cabinetry, model making and light-duty joinery.
Built around a tough, hi-tech resin body, these clamps are both lightweight and highly durable, with excellent resistance to temperature changes. The smooth trigger mechanism applies up to 70kg of clamping pressure (686N), giving you a firm, consistent hold without overexertion. Non-marking pads stay securely in place to protect delicate surfaces, while the 60mm throat depth allows you to reach further into your work with confidence.
Quick to convert from clamp to spreader, this versatile tool adapts instantly to your needs, helping you work faster and more efficiently. Backed by Axminster’s lifetime guarantee, it’s a dependable addition to any toolkit, whether you're a hobbyist or a seasoned maker.
Clamp Throat Depth 60 mm
Warranty Axminster Clamps Lifetime Guarantee
Clamping Capacity 150 mm
EAN Barcode 5052511144105
