Axminster Engineer Series Dial Test Indicator
- Used for measuring eccentricity of rotating parts in the lathe
- Spherical ended, spring loaded arm moves up to 1.3mm either way
- 30mm diameter dial calibrated in 0.01mm steps
- 6mm or 8mm mounting stems
The Digital Test Indicator is used for measuring eccentricity of rotating parts and for setting work accurately in the lathe. The spring loaded arm, which has a spherical end for accurate location on the work, moves up to 1.3mm either upwards or downwards from the central position for maximum flexibility of use. The 30mm diameter dial is calibrated in 0.01mm steps, making this a very precise instrument indeed. There is a choice of either 6mm or 8mm mounting stems which slide onto a dovetail strip on the back of the indicator body.
EAN Barcode | 5052511019816 |
- Standard Delivery* - £1.99
