Axminster Workshop Metric Vice-Versa Tape
- Dual reading universal tape for right or left hand use
- Scales on the blade read left to right and right to left
- Scales printed on both sides
- Non-Reflective Matt Finish Blade
- Lock button and return brake
- Heavy-duty ruberised grip case
- Triple rivet double sided end hook
- 25mm wide blade
- Class 2 accuracy
Left to right, right to left, top to bottom, whichever way you look at it this tape is easy to read. The dual reading metric blade is printed with scales on both sides and all edges so now you don't have to guess or read upside down. You can take a measurement from either the left or the right without any problem. Because the blade markings are printed on the underneath of the blade you can also do the same when working overhead. Heavy-duty soft grip case, lock button and triple rivet double sided end hook, 25mm wide blade, metric only.
EC Accuracy | Class II |
Graduations | Metric Only |
Tape Width | 25 mm |
