Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
A traditionally designed beechwood bench equipped with a heavy duty top, tool well at rear and one wooden vice with central screw and twin support bars plus a traditional L shaped tail vice. Built to a very high standard from European beech, the frame members are 40mm by 80mm, the top is a very substantial 50mm thick with 110mm deep edgings and there is a total of 13, 19mm dog holes for clamping longer lengths of timber with the tail vice. The overall width of the working surface is 615mm, including a tool well of 150mm. The end tail vice is 220mm wide and the front vice 520mm, giving plenty of holding width for large pieces of timber. Tool storage is catered for by an underslung drawer, 400mm long. Four 19mm steel bench dogs are provided, two short and two long. The bench is supplied flat packed, so home assembly will be required.
All Axminster workbenches are lacquered top and bottom to help maintain flatness. However, if your workshop is known to get damp, you may need to add more layers of lacquer to help prevent movement.
This product is classified as a Large Delivery
product and will normally be delivered within 3-5 working days.
This is a Palletised Large Delivery service.
A specialised palletised goods carrier that will deliver to kerbside only.
The carrier will be in contact to confirm the delivery date.
UK Mainland - £60
UK Remote & Offshore* - charge advised in basket
