Axminster Professional 4 Sided Workbench
- 1,200mm square beech top with reversible central toolwell
- Strong welded steel frame with diagonal cross bracing
- Ideal for schools or furniture workshops
The Axminster Professional workbench designed with the educational workshop in mind. The 1,200mm square top will allow up to four students to share a sensible sized workspace.
The top is 40mm thick with a 30mm downstand and constructed from durable beech wood, it features a reversible square tray in the centre. This tray either lies flush with the surface to give a large working area or when reversed it acts as a toolwell.
The base is a fully welded powder coated steel frame. The tubular steel legs are 75mm diameter. Diagonal cross bracing makes it an extremely rigid structure and allows wheelchair users to comfortably access the bench.
This is a quality bench, perfect for a school workshop or for furniture assembly and similar large projects. Made in UK.
EAN Barcode | 5052511126361 |
Nett Weight | 66 kg |
Overall L x W x H | 1,200 mm x 1,200 mm x 825 mm |
Thickness of Top | 40 mm |
This product is classified as an Enquiry product. Enquiry products require contact with our friendly team prior to purchase to understand your requirements. Typically these products have many customisation options or require product training.
Enquiry products are usually readily available and often despatched directly from the manufacturer using the best delivery service available. Despatch times can vary between manufacturers and delays may occur should stock become unavailable. Please contact customer services for more information.
