Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The AP150BS is a strong, robustly built belt sander, fabricated from heavy gauge steel plate and cast iron components. It provides good versatility, the belt arm can be used in any position from horizontal to vertical. The belt arm pivots around a very large flange with a graduated scale with the outer end of the belt drive roller supported in its own ball bearing assembly. Fitted with a very comprehensive guarding system that allows you to expose only the amount of sanding belt required, but still allows very easy changes of the belts. This machine has a large cast iron sanding table, which gives great support and tilts from -15° to +45°. If used as a linisher in the horizontal position, the guarding can be removed to expose the maximum amount of belt, a fixed work stop is provided. The close fitting guarding coupled with two 62mm dust outlets offers effective extraction when attached to a suitable fine dust collector. Uses standard 150 x 1,220mm abrasive belts. Supplied with one belt.
Sturdy and robust, fabricated from heavy gauge steel plate and cast iron
Can be used in any position from horizontal to vertical
Two 62mm dust outlets offer effective dust extraction
Machine Classification
