PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
Extremely versatile and offering great value for money
This Professional benchtop bandsaw offers great performance in a small space.
Designed by Axminster Tools
Our in-house designers have designed a fantastic bandsaw to meet the high standards required for the professional user.
Small and compact
This professional bandsaw is packed with many features found on bigger machines, meaning you get more for your money with Axminster Tools.
Generous depth of cut
Delivering 160mm depth of cut and 250mm width, this bandsaw is able to manage the most demanding of tasks.
Rack & Pinion Adjustments
The rack & pinion adjustment on the table tilt and upper blade guide height makes it quick and easy when setting up. Super smooth starting, acceleration and deceleration which is all powered by a 750W motor.
High quality cast iron table
The fine finish, heavy duty cast iron table aids to reduce vibration and allows smooth travel of the workpiece.
Rip fence with fine adjustment
The heavy duty rip fence with fine adjustment aids to quick and easy set up.
Ball bearing blade guide with micro adjustment
This helpful feature enables you to quickly and easily get set up, meaning there’s less downtime.
Dynamically balanced cast iron wheels
The high quality wheels aid towards low vibration while you work.
750W motor
The powerful motors means you are able to deliver ample power for the biggest cuts.
Inverter drive variable speed
This enables you to cut multiple materials with the correct blade.
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
This benchtop bandsaw offers great performance in a small space. The 750W induction motor has an inverter drive that varies the speed in the range 42 to 1,001 m/min. Using the lower belt position and reducing the motor speed the AP1854BV can be used for cutting metal. With the correct blade fitted it will cut mild steel-plate up to 10mm thick. Thicker or harder materials such as stainless steel cannot be cut in volume on this bandsaw. The heavy gauge welded, one piece frame is extremely rigid to withstand high blade tensions. The cast iron table features a ground table surface and a rack and pinion tilt mechanism with indexing stops for common angles. The heavy gauge alloy rip fence is mounted on a cast alloy bracket which also incorporates a fine width adjustment. The fence is clamped with a cam action lever, easily released to allow swift adjustment. Blade guides are all ball bearing with micro adjustment for accurate control. The top guide is mounted on a steel hexagon bar for stiffness and adjusted for height by a small rack and pinion system. The cast iron band wheels are precision machined and balanced.
This model is a true all round machine, suitable for many kinds of projects using all kinds of materials. Supplied with a 1/2" x 6tpi bandsaw blade.
An optional floor stand is available, featuring adjustable height feet to give a comfortable working height.
Machine Classification
