Axminster Professional AP200SRG Slow Running Grinder - 230V
107671
From £185.98 £154.98
47 Reviews
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
Please check Click & Collect in-store stock for availability.
  • Especially suited to the edge tool grinding needs of the woodworker or turner
  • 60-grit grey and 120-grit white aluminium oxide 200mm x 32mm wide wheels
  • Slow running speed of 1,425rpm, less chance of overheating the tool
  • Generously sized, adjustable grinding rests
  • LED work light fitted
  1. Axminster Professional AP200SRG Slow Running Grinder - 230V
Total:
£371.12 £309.27
This solidly made 200mm Trade rated grinder is fitted with a 60-grit grey and a 120-grit white aluminium oxide wheel, both 32mm wide and well suited to the edge tool grinding needs of the woodworker or turner. The speed is reduced to 1,425rpm thus reducing the peripheral speed and the potential to overheat the tool. The base is 200 x 320mm and has four fixing points. The 900W induction motor runs exceptionally smoothly and provides adequate power for all types of grinding. The guards are very solid and have 45mm diameter outlets at the rear for connection to an extraction system. The tool rests and eye shields are robustly made, the eye shields being fully adjustable to any position. Finally, to finish off a good job the grinder is fitted with an LED work light and no-volt-release switch. Please note, SIT Wire Brushes not compatible with this grinder.
Note: When a grinder is new or when changing stones it is important to dress the stones to ensure the front face runs true. We recommend using a suitable dresser in order to get the most out of your grinder.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
4.00 47
