This medium weight, trade-rated nail gun fires 16 gauge T-headed brad nails from 20mm to 50mm in length. With its low air consumption, this nailer can be used with any of the smaller 25-litre capacity compressors. It can be used with standard trigger firing or in bump mode where, with the trigger engaged, a nail is delivered each time the safety stop is depressed, useful for fast fixing.
The gun is easy to load and the handle has a high grip rubber covering. An adjustable exhaust air outlet means that the exhaust can be directed to where convenient.
A 1/4" BSP quick release male Euro bayonet fitting is provided in the back of the tool for direct connection to the airline. Supplied in a plastic storage case.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
