Axminster Professional AP2260BS2 Belt Sander - 230V
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Sands either vertically, horizontally or any angle between
- Sanding belt oscillates for a scratch-free finish and longer abrasive life
- Table height adjustment by geared handwheel for precision setting
Smooth running, quiet and very useful!
If you're looking for a robust, well made and hassle-free machine, this belt sander has got to be one of the most useful machines to have in any woodworking workshop.
Achieve professional results
The sanding belt oscillates for a scratch-free finish and longer abrasive life.
Easy to use
With rack & pinion table adjustment, it is quick and easy to move the table to where you need it.
Sand at any angle
Whether you need to sand vertically, horizontally or any angle in between, this belt sander is the perfect choice!
Need to carry out curved work?
Thanks to the small sanding table, curved work is a breeze.
Buy with confidence
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price £69.97 £58.31 was £89.98 £74.98 Save £20.01 £16.67
This compact belt sander is a well made and relatively simple machine. With a 2.2kW motor driving a 150mm wide belt, it is one of the most useful machines to have in any woodworking workshop. The belt drive has an automatic oscillating action to provide a scratch-free finish and longer abrasive life. The belt also runs on a graphite anti-friction plate. The whole belt platen can tilt through 90° from vertical to horizontal, the precision ground cast iron table being easily adjusted in two planes to suit. The table has a stanadard 3/4" x 3/8" mitre slot to take a mitre fence. The dust hood can be rotated to clear the end of the belt for easy belt changing, and also to allow a small table to be mounted for sanding curved work. The stand is made from thick gauge welded steel and had a very useful belt storage cupboard. Smooth running, quiet in use, a very useful finishing machine. Supplied with a 150mm x 2,260mm 80G abrasive belt fitted.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Axminster Professional 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
Abrasive Belt Size | 150 mm x 2,260 mm |
Belt Speed | 960 m/min |
Dust Extraction Outlet | 100 mm |
EAN Barcode | 5052511124404 |
Min Extraction Airflow Required | 1,000 m³/hr |
Model | AP2260BS2, 106707 |
Nett Weight | 120 kg |
Overall L x W x H | 1,325 mm x 570 mm x 1,235 mm |
Plug Fitted | UK 16A Plug |
Power | 2.2 kW |
Rating | Trade/Professional |
Sound Pressure Level LpA [Uncertainty K] | 81 dB(A) [3.0 dB] |
Table Size | 750 mm x 250 mm |
Table Vertical Travel | 80 mm |
Voltage | 230 V |
- UK Mainland - £70
- UK Remote & Offshore* - charge advised in basket
