Precision grinding power in a compact, portable design
The Axminster Professional AP250FSG delivers high-torque performance, fine control, and hands-free operation — ideal for intricate work on a wide range of materials.
High-torque, low-noise brushless motor
The DC24V motor will deliver high torque, even at low speeds, making it invaluable for a wide range of materials and applications. Plus, enjoy the bonus of a quiet running machine.
Variable speed with RPM display
Accurately control and set the optimum speed setting for your application using the built-in variable speed adjustment. With the RPM tachometer, you can clearly see what speed you're working at.
Foot pedal for hands-free control
Enjoy hands-free operation thanks to the instant control foot pedal – this will come into its own when doing tasks requiring frequent on-off control.
Compact, portable design
Compact enough to easily store out of the way to save workshop space, without having to compromise on power.
Versatile applications
Able to handle wood, glass, leather, stone and more, the AP250FSG can be used for engraving, cutting, drilling, grinding, and polishing.
Wide range of accessories
Choose from three handpieces designed specifically for this tool, and a varied range of compatible tools, bits, and cutters to suit the task at hand!
The Axminster Professional AP250FSG Flexi Shaft Grinder is a compact, high-performance tool designed for precision work across a wide range of materials. Whether you're engraving, cutting, drilling, grinding, carving or polishing, this versatile grinder handles wood, glass, leather, stone, and more with ease. Its robust construction ensures long-lasting durability, and its lightweight, portable design makes it easy to transport and store - perfect for those working across multiple locations or with limited bench space.
Engineered for precision and control, it features a high-torque, low-noise DC24V brushless motor that maintains consistent performance even at low speeds. The built-in variable speed adjustment and RPM tachometer allow you to fine-tune your settings and record them for future use, while the forward/reverse switch enhances flexibility during operation. A foot pedal provides instant start/stop control, giving you hands-free operation and greater precision - especially useful for intricate or repetitive work.
To get the most from your AP250FSG, don’t forget to select the right handpiece for your needs (sold separately). Choose from three styles: the HC110 Chuck Style, HC120 Chisel Style, or HC130 Collet Style. A wide range of compatible accessories is also available, including rasps, chisels, and cutters - everything you need to customise your setup for any application. With its enhanced performance and user-friendly features, the AP250FSG is a valuable addition to any workshop.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
