PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The AP254LTS is compact, sturdy and well built table saw. It has a thick steel, welded base, supporting the entire workings of the machine on widely spaced trunnions. A cast iron frame supports the motor and blade arbor, giving rigid and solid blade support.
The ground surface cast iron table is completely stress free and has two 19mm mitre fence slots, and a steel kerf plate. The saw comes with phenolic right-hand and rear extension tables, giving you plenty of support when cutting sheet materials.
The blade height and tilt controls are very smooth using the cast iron handles. The full length rip fence has a T-square style mounting. It slides smoothly into position and locks rock solid. A Hi-Lo sliding fence rail offers versatility for thin or thick work. The cast iron mitre fence features pre-set angle stops.
Dust extraction is direct from the lower blade housing, with a cleverly designed crown guard directing airflow from the blade above the table. A single 100mm port allows easy connection to a suitable dust extractor.
Optional accessories include a 1,400mm sliding table complete with a UJK sliding table fence, the S-12 Overhead Crown Guard System, and a Dado Blade Set.
NOTE: AP254LTS requires a 16amp supply if used with a dado set.
Machine Classification
This product is classified as a Large Delivery
product and will normally be delivered within 3-5 working days.
This is a Palletised Large Delivery service.
A specialised palletised goods carrier that will deliver to kerbside only.
The carrier will be in contact to confirm the delivery date.
UK Mainland - £60
UK Remote & Offshore* - charge advised in basket
